March 18, 2017, 00:23 |
the continuity residual is not converging
Cakov
Rep Power: 9 |
file:///C:/05_AS002BEME5/mecca/mecca02_files/dp0/FLU/Fluent/SYS.2-5-00248.jpg
i am simulating a car park with jet fans. both inlet and outlet of the fans are labeled with fans(boundary condition). the pressure jump at the outlet is 700Pa. a steady state, standard k-e turbulence, pressure-velocity is coupled. how to reduce the continuity residuals? pls help me! |
March 18, 2017, 06:25 |
Behrooz Jamshidi
Rep Power: 13 |
Hi
If your setup is correct then try increasing your mesh density in high gradient regions. |
March 19, 2017, 05:02 |
Rep Power: 10 |
What's your mesh quality like?, I've generally found that continuity is particularly sensitive to the quality of the mesh and won't converge when the other quantities will.
p.s. With images I find it's best to upload then to a storage website, like Imgur, first and then link them here. I don't think you can directly upload to to here (anymore?). |
March 19, 2017, 06:53 |
Cakov
Rep Power: 9 |
March 19, 2017, 07:02 |
#5 | |
Cakov
Rep Power: 9 |
Relevance center is fine. Smoothing is high Transition is Fast Span angle center is fine The rest is set as default. |
July 20, 2017, 17:15 |
yardena jodeck
Rep Power: 9 |
I have the same problem. I decided to accept that value and and use more convergence criteria.
Maybe someone here that knows more than us can say if this is ok or not Sent from my SM-G570M using CFD Online Forum mobile app |
continuity residual, fluent, jet fan |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 06:28 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
