How fluent calculate the pressure by velocity profile?
Old   March 10, 2017, 12:14
Default How fluent calculate the pressure by velocity profile?
Marco Ghiani
drudox is on a distinguished road
Hi there !
I've got a question .. I have a inlet profile for a turbine blade, (by experimental result) , now ... I have to use pressure inlet boundary (rightnow I've put the velocity profile and run simulation for a while .. then i write the PRESSURE profile and change the boundary to pressure inlet ... )
Now the question is .. if I want know which pressure profile without using this "tricks" ?? consider that the velocity at the inlet surface is 20 ~ 40 m/s
how can i calculate it ?
Thanks in advance
drudox is offline   Reply With Quote
Old   March 10, 2017, 16:20
Lucky
Thanks in advance
It's not a trick. In general that is the way you have to solve it. You have a domain and you want to impose some boundary conditions. The variables that you do not explicitly declare you must solve for.
Alternatively you can start to make some assumptions about the problem, but this is just a way of turning off the physics.
how to put udf inlet velocity and udf outlet pressure in fluent raminostadi Fluent UDF and Scheme Programming 4 July 3, 2017 07:43
Straight Pipe with imported velocity profile. Pressure gradient? Ahuja.Darsh FLUENT 7 September 13, 2016 09:11
Fluent & CFD code calculate Static pressure vhcongtltd FLUENT 0 November 2, 2013 09:24
Fluent & CFD code calculate Static pressure vhcongtltd ANSYS 0 November 2, 2013 09:22
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 03:13
