March 4, 2017, 12:20 |
Velocity inlet inside another zone
Thomas
Rep Power: 9 |
Hello there,
I am trying to simulate air flowing inside an inclined rectangular cavity. The extensions at the inlet and outlet of the cavity are there to impose ambient temperature and pressure such that the air is accelerated from the rest to the induced velocity. There probably exist a simple solution to this one but... How can I select the small cavity inlet to be the velocity inlet? The problem is that the small cavity inlet is touching the large extension cavity and FLUENT sees it as a contact, rather than velocity inlet. I'd appreciate your help. cfd.jpg Thanks, Thomas |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 11:25 |
Setting Density for Velocity Inlet Face | arkie87 | FLUENT | 0 | November 7, 2012 15:15 |
UDF problem : inlet velocity in cyl. coord. system | Jongdae Kim | FLUENT | 0 | June 15, 2004 11:21 |
