flocculation Divergence detected in AMG solver: bin-1-fractio
Old   March 3, 2017, 05:57
Default flocculation Divergence detected in AMG solver: bin-1-fractio
Firdaus Abidin is on a distinguished road
hi all, im using Fluent 17 to simulate a simple flocculation tank with baffle. im new to CFD in general.
im using population balance model because that is what i read others are using and the setting that i use are as follow:
multiphase- Eulerian with 2 eluerian phase and 1 discrete phase
viscous- k-epslon
-k-epslon model is realizable
-near wall treatment is scalable wall functions
-turbulence multiphase model is dispersed
discrete phase model- in the physical models i thick erosion/accretion and breakup
-i created injection with surface type. from the release from surfaces i chose inlet
-the material chosen is ash-solid
-in the point properties the stop time is 10s and the velocity is 0.01 m/s. the scale flow rate by face area and injection using face normal direction are chosen.
population balance model- method discrete
- the phases is water
- the nucleation rate, growth rate, aggregation and breakage all have a constant value of 0.1 and Ramakrishna is chosen for the formulation
boundary condition- at the inlet the water velocity 0.1, volume fraction 0.9, bin-0 fraction 0.1 and bin-1 fraction 0.3
- at the outlet, backflow volume fraction is 0, bin-0 fraction is 0.2 and bin-1 fraction 0.3
the solution initialization method use is hybrid.
when i run the calculation i get an error below:
Error: Divergence detected in AMG solver: bin-1-fraction
Error Object: #f
i already googled for solution but have not found any that works for my case.
i will appreciate it greatly if anyone can give me a suggestion on how to solve this problem.
Firdaus Abidin is offline   Reply With Quote
amg solver, divergence
PEMFC model with FLUENT brahimchoice FLUENT 22 April 19, 2020 16:44
Divergence detected in AMG solver: pressure correction xinquanzhoucn FLUENT 5 July 21, 2014 05:49
Floating point error and divergence detected aannjj FLUENT 0 July 2, 2013 04:44
3d vof Smaras FLUENT 2 February 19, 2013 07:58
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
