Write xy plot for every design point
Old   March 1, 2017, 09:20
Default Write xy plot for every design point
Hannes
hannesjk is on a distinguished road
Hello!
I have a model of which i want to calculate the pressure difference between inlet and outlet for different geometry parameters. I use workbench to add all the different geometries in design points. I wonder if i can, for every design point, make Fluent write an XY-plot with pressure difference along a line between inlet and outlet. I can easily do this manually in Fluent, but is it possible to do it automatically for every design point?
Also is there a way to calculate the average pressure for all cross sections along a line instead of just for each point along a line?
Thanks!
hannesjk is offline   Reply With Quote
Old   March 1, 2017, 12:34
Hannes
I found out that you can use macros to do this. The problem is that the macro is deleted every time workbench changes to a new design point. Is there a way to solve this?
Old   July 4, 2017, 02:12
mohammad
myaghoobi2 is on a distinguished road
Hi
An easy way to do it: you can run all your design points and save the data files of fluent. Then write a script for workbench that change the "current design point" and open CFD-post and then write that xy data you need.
about that problem you said : "The problem is that the macro is deleted every time workbench changes to a new design point" also you can write a really simple script -by means of record journal script that is available in Workbench>>file>>scripting- that in each design point load and interpret a macro at beginning of solution.
if you have got more questions about that scripting do not hesitate to contact me:
http://mech.sharif.ir/~yaghoobi_mohammad/
Tnx
myaghoobi2 is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
Parameter Design point update Workbench 14 snpradeep CFX 16 December 7, 2020 15:49
paraview - cell data or point data on plot over line bye bye my blue OpenFOAM 0 December 13, 2016 07:07
How to request cfx to write variables at a point? Uday CFX 1 February 6, 2006 00:42
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 16:56
