Species Transport Convergence trouble in Supersonic Flow
Old   February 28, 2017, 13:18
Default Species Transport Convergence trouble in Supersonic Flow
Brian B.
BrianF16 is on a distinguished road
Hello-
I am a very new user to ANSYS Fluent and was assigned it to complete a Master's distance learning project for a class that I am currently taking.
I am analyzing skin friction and surface heating in a 2D supersonic flow with different fuels being injected into the BL. The flow properties are Mach 5 at the inlet, with a gauge static pressure of 83000 Pa. I am using a Chemkin mechanism for H2 oxidation, with 10 species and 21 reactions. I have success when I do not initiate the reaction mechanism, i.e. a cold flow, and am able to get a converged solution in this case. When I initiate the reaction, the residuals for continuity, x-velocity, and y-velocity jump to around 1e-01, and the residuals for the species jump 10 orders of magnitude, with some being around 1e+09. I know this isn't right.
I've checked my mesh, it's got around 300000 nodes and is finer around the fuel-inlet and boundary layer. I can't do much more refinement to the mesh as it's the student version of ANSYS and I am limited to around 500000 nodes.
As far as the solver goes, I using a density based solver with reduced under-relaxation factors. I'm using the standard k-e viscous model as well as enabling the stiff chemistry solver for the species transport. I've treied changing the viscous model to start with S-A or even laminar flow to no avail.
Any help or ideas would be appreciated. Thanks.
BrianF16 is offline   Reply With Quote
combustion, scramjet, species, supersonic, transport
convergence problems by species transport Felipeb FLUENT 10 July 15, 2018 08:45
species transport convergence aliemadi FLUENT 1 November 14, 2016 10:30
user defined scalar vs species transport gvj_mech FLUENT 0 March 27, 2014 15:33
Jet in Supersonic Crossflow, controlling mass flow rate ChrisA OpenFOAM Running, Solving & CFD 3 November 13, 2012 19:20
Laminar flow in species transport model? Neha Rao FLUENT 7 February 25, 2006 03:23
