February 28, 2017, 06:25 |
Fluent Airfoil Analysis: Fixed CL mode
I've performed some analyses on supercritical airfoils with the code SU2; I used the 'FIXED_CL_MODE' of Su2, to evaluate the behaviour of the airfoils at different Mach conditions, fixing the target CL (useful to evaluate de Drag Rise condition and the influence of the lift coefficient on transonic performances). I want to realize the same analysis in Fluent, but I don't know if is it possible to perform a FIXED CL calculation in Fluent. Is there a way (not only a direct command but also a script) to fix the target CL before performing a 2D calculation in Fluent? Thank You! |
airfoil, fixed cl, fluent, transonic |
Problem with airfoil shape optimization | robyTKD | SU2 Shape Design | 7 | March 7, 2022 17:18 |
fluent 12.1, batch mode in linux | sakalido | FLUENT | 13 | September 27, 2017 09:55 |
Fixed CL mode in SU2 V4.2 | ygd | SU2 | 0 | November 15, 2016 10:59 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 10:26 |
Fluent Batch Mode Reg_ Urgent Help Required | alligngr8 | FLUENT | 4 | January 12, 2012 09:21 |
