February 28, 2017, 03:49 |
Setting the equivalence ratio
Matthew Hastings
I am trying to accurately model a non premixed diesel compression-combustion dual stroke. I understand how to set the mixture fractions in Ansys Setup: in my fuel injection stream: Diesel=1; in my chamber air mixture: n2=0.76, o2=0.23, co2/h20=small. However, although this ensures the correct mixture fraction ratios in the chamber, it does not ensure the correct mass of oxygen for stoichiometric combustion. As far as I can see, the only way to set the equivalence ratio is to: set your engine dimensions; calculate the mass of oxygen based on the volume, volume ratio and material properties; tailor your fuel injection profiles such that stoichiometric conditions are achieved. Is this the only way? Thank you in advance. Sent from my SM-J320FN using CFD Online Forum mobile app |
March 2, 2017, 16:13 |
Lucky
Rep Power: 66 |
Yes that is the only way.
Actually, in real life that is how you do it also. The hand of God does not just shove more air into your combustion chamber for you. |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 10:53 |
pressure eq. "converges" after few time steps | maddalena | OpenFOAM Running, Solving & CFD | 69 | July 21, 2011 08:42 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
