impingement jet injector
Old   February 25, 2017, 14:08
Default impingement jet injector
Boris
Hawxliquid is on a distinguished road
Hello.
I am trying to simulate the impigement of water jets on each other ( like this : http://heroicrelics.org/info/f-1/f-1...t-patterns.jpg )
What should I use ? VOF ? DPM ? Is there any tutorial that could help me ? Thanks ! ( Also, I tried with VOF, but I seem to have a lot of issues, and I Can't even define the velocity inlet.. )
Thank you !
Hawxliquid is offline   Reply With Quote
Old   February 25, 2017, 18:29
Lucky
The DPM model is more appropriate for discrete phases, like a particle moving around in your flow. I think a volume-fraction approach is more suitable. Try the VOF model or a full Euler-Euler model.
Btw Fluent only has a primary liquid jet breakup model, it can't simulate secondary breakup. So don't be surprised if results don't match. I.e. the jet that comes out of these mostly evaporate and they don't slowly break down into droplets. It does have a primary atomization model though, which just assumes that your liquid jet has already broken into droplets as soon as it enters the domain.
Old   February 9, 2018, 14:43
Default No secondary breakup?
daniel_pramudita is on a distinguished road
Hi LuckyTran,
I got confused with your statement that Fluent doesnot have secondary breakup models. As far as I know, it explicitly provide some secondary breakup models (for droplet, I believe), which are in the DPM.
What case are you referring here?
Daniel
daniel_pramudita is offline   Reply With Quote
Flame jet impingement transient analysis anilkadam FLUENT 5 October 11, 2016 16:15
Velocity Profile for Cureved surface Jet Array Impingement Case ara STAR-CCM+ 4 February 4, 2015 06:24
Best Turbulence Model for Heat Transfer in Jet Impingement ara STAR-CCM+ 5 July 25, 2014 12:45
Water Jet Impingement Ahmed Omar CFX 0 April 13, 2006 19:20
JET IMPINGEMENT G.Balakrishnan FLUENT 1 December 9, 2000 13:17
