February 24, 2017, 00:16 |
Writing a profile file for inlet velocity
AMEET KUMAR
Rep Power: 9 |
Please can someone help me to write a profile file for fluid inlet velocity in recipricating pump which is rotating at 1450 rpm and total displacement of piston is 20 mm.
Diameter of piston is 14 mm. |
February 25, 2017, 00:43 |
Lucky
Rep Power: 66 |
What's your profile?
February 26, 2017, 23:22 |
AMEET KUMAR
Rep Power: 9 |
I have to write a profile file for water displacement with piston movement inside the cylinder
February 27, 2017, 00:53 |
Lucky
Rep Power: 66 |
Yes but what is your profile?
u(x,y,z,t) = what? v(x,y,z,t) = what? w(x,y,z,t) = what? |
February 27, 2017, 06:22 |
AMEET KUMAR
Rep Power: 9 |
Sir I dont know my profile, I have to write the velocity profile for fluid velocity inside the cylinder during the piston movement, the piston pump is rotating at 1450 rpm and the crank radius is 10mm, piston diameter is 14mm, movement of piston is in X-direction Thats all I know.
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
