February 23, 2017, 16:16 |
Error: receveid a fatal signal
MATTEO CELONE
I'm trying to test a heat flux profile in the wall using an udf code, but when I interpreted the udf it appeard a message of N2 definition shadows previous definition, and it doesnt work, giving me another heat flux. My problem is a cooling channel in a rocket chamber and has a complex heat flux distribution.
the udf code is this: #include "udf.h" # define pi (3.14159) DEFINE_PROFILE(Boun_Cond, t, i) { real x[ND_ND]; /* this will hold the position vector */ real rt, dt, At, vis, Cp, Pr, Pc, Tc, gamma, Cstar, g, r, A, M, Mnew, N1, N2, N3, Taw, sigma, hgas, func, ffunc, fCO2, fH2O, Le, qrad, qCO2, qH2O, P, Pcr; face_t f; int k,NI,a; rt=0.1; /* m */ vis=0.00010863; /* kg/m-s */ Cp=2083.3; /* J/kg-K */ Pr=0.63; Pc=6000000; /* Pa */ Pcr=61.18297; /* kg/cm2 */ Tc=3570.44; /* K */ gamma=1.146; Cstar=1804.7; /* m/s */ NI=100000; dt=rt*2; At=pi*pow(rt,2); fCO2=0.11917; /* Mole Fraction of CO2 */ fH2O=0.31769; /* Mole Fraction of H2O */ begin_f_loop(f,t) { F_CENTROID(x,f,t); r=sqrt(pow(x[a],2)+pow(x[1],2)); A=pi*pow(r,2); Le=0.6*2*r; /* For Combustion Region */ if (x[0]<0.28) { M=0; P=Pcr/pow((1+(gamma-1)*pow(M,2)/2),(gamma/(gamma-1))); Taw=Tc*((1+pow(Pr,0.33)*((gamma-1)/2)*pow(M,2))/(1+((gamma-1)/2)*pow(M,2))); sigma=pow((0.5*F_T(f,t)/Tc*(1+(gamma-1)* pow(M,2)/2)+0.5),-0.68)*pow((1+(gamma-1)*pow(M,2)/2),-0.12); hgas=0.026*pow(vis/dt,0.2)*Cp*pow(Pc/Cstar,0.8)*pow(At/A,0.9)* sigma/pow(Pr,0.6); /* Radiation Heat Transfer */ qCO2=4.0705*pow((P*fCO2*Le),1/3)*(pow((Taw/100),3.5)- pow((F_T(f,t)/100),3.5)); qH2O=4.0705*pow(P*fH2O,0.8)*pow(Le,0.6)* (pow((Taw/100),3)-pow((F_T(f,t)/100),3)); qrad=qCO2+qH2O; } /* For Subsonic Region */ if (x[0]<0 && x[0]>=0.28) { for(k=1;k<=NI;k++) { if(k==1) M=0.05; else if (k!=1) M=Mnew; N1=2/(gamma+1); N2=(gamma+1)/(2*(gamma-1)); N3=1+(gamma-1)*pow(M,2)/2; func=pow(N1,N2)*pow(N3,N2)/M-A/At; ffunc=-pow(N1,N2)*pow(N3,N2)*pow(M,-2)+ pow(N1,N2)*N2*pow(N3,N2-1)*(gamma-1); Mnew=M-func/ffunc; if(fabs(Mnew-M)<0.01) break; } P=Pcr/pow((1+(gamma-1)*pow(M,2)/2),(gamma/(gamma-1))); Taw=Tc*((1+pow(Pr,0.33)*((gamma-1)/2)*pow(M,2))/ (1+((gamma-1)/2)*pow(M,2))); sigma=pow((0.5*F_T(f,t)/Tc*(1+(gamma-1)* pow(M,2)/2)+0.5),-0.68)*pow((1+(gamma-1)*pow(M,2)/2),-0.12); hgas=0.026*pow(vis/dt,0.2)*Cp*pow(Pc/Cstar,0.8)*pow(At/A,0.9)* sigma/pow(Pr,0.6); /* Radiation Heat Transfer */ qCO2=4.0705*pow((P*fCO2*Le),1/3)*(pow((Taw/100),3.5)- pow((F_T(f,t)/100),3.5)); qH2O=4.0705*pow(P*fH2O,0.8)*pow(Le,0.6)* (pow((Taw/100),3)-pow((F_T(f,t)/100),3)); qrad=qCO2+qH2O; } /* For Supersonic Region */ if (x[0]>=0) { for(k=1;k<=NI;k++) { if(k==1) M=20; else M=Mnew; N1=2/(gamma+1); N2=(gamma+1)/(2*(gamma-1)); N3=1+(gamma-1)*pow(M,2)/2; func=pow(N1,N2)*pow(N3,N2)/M-A/At; ffunc=-pow(N1,N2)*pow(N3,N2)*pow(M,-2)+ pow(N1,N2)*N2*pow(N3,N2-1)*(gamma-1); Mnew=M-func/ffunc; if(fabs(Mnew-M)<0.01) break; } P=Pcr/pow((1+(gamma-1)*pow(M,2)/2),(gamma/(gamma-1))); Taw=Tc*((1+pow(Pr,0.33)*((gamma-1)/2)*pow(M,2))/ (1+((gamma-1)/2)*pow(M,2))); sigma=pow((0.5*F_T(f,t)/Tc*(1+(gamma-1)* pow(M,2)/2)+0.5),-0.68)*pow((1+(gamma-1)*pow(M,2)/2),-0.12); hgas=0.026*pow(vis/dt,0.2)*Cp*pow(Pc/Cstar,0.8)*pow(At/A,0.9)* sigma/pow(Pr,0.6); /* Radiation Heat Transfer */ qCO2=4.0705*pow((P*fCO2*Le),1/3)*(pow((Taw/100),3.5)- pow((F_T(f,t)/100),3.5)); qH2O=4.0705*pow(P*fH2O,0.8)*pow(Le,0.6)* (pow((Taw/100),3)-pow((F_T(f,t)/100),3)); qrad=qCO2+qH2O; } F_PROFILE(f,t,i) = (hgas*(Taw - F_T(f,t))+qrad); } end_f_loop(f,t) } |
[ImmersedBoundary] About the moving immersed boundary tutorial: icoDyMIbFoam+movingCylinderInChannelIco | wyldckat | OpenFOAM Community Contributions | 25 | September 14, 2021 17:15 |
fluentError: received a fatal signal (Segmentation fault). | thomaszhangjing | Fluent UDF and Scheme Programming | 11 | January 13, 2021 09:37 |
FLUENT received fatal signal (ACCESS_VIOLATION) | osamaghani | FLUENT | 2 | March 31, 2012 16:15 |
FLUENT received fatal signal (ACCESS_VIOLATION) | Saikiran | FLUENT | 3 | March 17, 2011 07:02 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
