burcu çiçek
Rep Power: 0 ![]() |
Hi everbody,
I am working on electronics cooling with natural convection. In my work I have modeled a chip, printed circuit board and heat sink and fins. Each part in contact with each other is defined as a different material. When I click solution initialization tab in fluent, a warning appears as "It is recommended that you fix this issue via the TUI command /mesh/modify-zones/slit-interior-between-diff-solids".How can i solve this problem. I'm glad you helped me. Best regards |
#2 | |
Kushal Puri
Rep Power: 12 ![]() |
contact |
Defining Planetary Motion | Sreyas14 | CFX | 7 | June 25, 2016 20:55 |
UDF for defining specific heat ratio,gas constant,molecular weight | n.soumya | Fluent UDF and Scheme Programming | 6 | February 17, 2016 08:37 |
defining boundary | flow_CH | FLUENT | 5 | June 4, 2013 17:01 |
creation of species and defining the inputs | sairam | FLUENT | 0 | September 17, 2009 14:38 |
WENO Scheme Defining Boundary Stencil | rampy | Main CFD Forum | 3 | January 15, 2007 00:08 |
