February 21, 2017, 03:15 |
Boundry condition of leaking pipeline
Lamont
I am doing a simulation of 3D pipe leakage and I need help on boundry conditions. Here are some details: 1. incompressible flow, transient, LES 2. INLET: velocity inlet, velocity=300m/s, gauge pressure=28bar 3. Two outlets: one is pipe and another one is leakage outlet What I want is the pressure contour. I need help on the outlet boundry conditions: Should I set those two outlets as pressure outlet? But what I want to get is the pressure and I don't know the gauge pressure... Or should I build an infinitely long cylinder(like T-junction pipe) at the leakage and set the pressure at the end of cylinder equals 0? Then what about my main outlet? Any assist would be very apperciated. Lamont |
incompressible flow, leakage, les |
Access cell volume from boundry condition | JimKnopf | OpenFOAM Programming & Development | 2 | March 10, 2011 04:29 |
Different Boundry Condition Type at the same face | cupidvenus | FLUENT | 5 | September 10, 2009 05:16 |
boundry condition problem | arashshahin | FLUENT | 5 | February 16, 2005 09:55 |
wall boundry condition | fred | FLUENT | 0 | August 19, 2004 12:10 |
Temperature rise at a boundry condition | Rodrigo | FLUENT | 5 | August 3, 2001 10:04 |
