How calculate the local heat transfer coefficient of a face?
Old   February 19, 2017, 10:09
Default How calculate the local heat transfer coefficient of a face?
h0rst is on a distinguished road
Hello everybody,
I want to export some results out of fluent to Ansys Classic. For that, I need to know the heat transfer coefficient between a wall and a flow. Then I want to export these values to Ansys classic.
Now, I am trying to find out the heat transfer coefficient of the contact phases. If I try to display them in the post processing, it only gives the values of the nodes. If I disable radio button "node values", I think the average rated cell values are calculated. What I need are the HTC of the faces between flow and wall.
Is it also possible to calculate that and does somebody know how?
Best regards
h0rst
h0rst is offline   Reply With Quote
Hi i need to find wall temperature to calculate local heat transfer coefficient. i d reslan FLUENT 0 February 25, 2016 11:58
Hi i need to find wall temperature to calculate local heat transfer coefficient. i d reslan FLUENT 0 February 25, 2016 11:57
High values of heat transfer coefficient for laminar flow in pipe Allankey CFX 2 May 28, 2014 13:44
Heat transfer coefficient CIN3X OpenFOAM Running, Solving & CFD 3 November 25, 2013 06:54
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
