February 16, 2017, 22:28 |
To check whether the solution is converging
raunak jung pandey
Rep Power: 10 |
I am carrying out transient simulation in fluent. Turbulence model used in k-e with scalable wall function. Velocity inlet condition is used and static pressure outlet condition is used.
Time step size is 0.002 giving courant number around 10. Absolute criteria for convergence of residual is 10^-6 Under relaxation factors are : Momentum 0.5 TKE 0.5 I am not sure if the solution is converging or not ? Please help me in the following : |
February 17, 2017, 08:40 |
Not at all.....
February 17, 2017, 18:42 |
raunak jung pandey
Rep Power: 10 |
It's a very simple domain and setup. What could be affecting convergence? I changed the relaxation factors right away . Does this affect convergence ?
Thank You Last edited by raunakjung; February 17, 2017 at 20:02. |
convergence check, flunet |
solution not converging for steady laminar flow | anillor | FLUENT | 0 | February 3, 2017 00:52 |
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 22:22 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 08:21 |
SOLUTION IS NOT CONVERGING | KHAN | FLUENT | 1 | September 23, 2005 02:03 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 02:16 |
