Defining the region between two layers of fluid in a reacting flow
Old   February 15, 2017, 22:49
Default Defining the region between two layers of fluid in a reacting flow
alaba
bamidoao is on a distinguished road
I am trying to simulate biomass reaction with sand in a cylindrical fluidising bed reactor. They are both being fluidised by nitrogen so I considered the three of them (sand, biomass and nitrogen) as fluid. However, the biomass sits on the sand before fluidisation by nitrogen. How do I define the region (height) of sand and biomass in the reactor.
Thank you guys and I am waiting for your reply.
N/B: I considered it to be two dimensional.
bamidoao is offline   Reply With Quote
Flow with source term and compressible::turbulentTemperatureCoupledBaffleMix ed bc Gerben OpenFOAM Running, Solving & CFD 0 January 19, 2017 09:08
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump Zev Xavier FLUENT 3 May 9, 2016 07:42
What will be the state or condition in fluid volume when flow is not full? shivasluzz CFX 2 May 17, 2015 03:59
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
