Convergence issues for Wavy walled cavity filled with nanofluid
Old   February 15, 2017, 14:31
Unhappy Convergence issues for Wavy walled cavity filled with nanofluid
Connor Furness
clfurness is on a distinguished road
Hi everyone,
I have a cavity defined by a left and right vertical wall, joined by two wavy horizontal walls.
I am manipulating Rayleigh number by changing 'g' and keeping the temperature difference as 1 k.
The vertical walls are adiabatic. The top wall is at 293 k and the bottom wall is at 294 k. This creates natural convection in the fluid, given that the change in temperature changes the density of the fluid, and so the the boussinesq model is used.
i have tried changing the relaxation factors using trial and error and not had a single simulation converge.
I have tried using a lower Rayleigh number and a courser mesh to try and get convergence on a 'simplified' model first, and re-solve again and again as i increase the rayleigh number and mesh back to the desired values.
I have these problems on both ANSYS 15.0 accademic and ANSYS student 17.2.
Can anyone help?
clfurness is offline   Reply With Quote
Old   September 3, 2017, 16:40
alireza keyhani
ali_reza is on a distinguished road
Hi
try manipulating Rayleigh number by changing Thermal expansion coefficient.
Regards
ali_reza is offline   Reply With Quote
boussinesq approximation, wavy
Convergence issues in extremely low Re problems santiagomarquezd OpenFOAM Running, Solving & CFD 0 October 28, 2014 11:53
Laminar Pipe Flow convergence issues preichl OpenFOAM Running, Solving & CFD 11 September 22, 2014 22:22
Grid size, convergence issues franzdrs Main CFD Forum 3 June 18, 2009 08:57
convergence issues (discontinuity mastered!) Matthew R FLUENT 0 October 12, 2006 04:55
RSTM convergence issues nazario Main CFD Forum 0 June 23, 2006 08:23
