February 14, 2017, 14:15 |
dpm mass flow rate
Yang
Rep Power: 11 |
I've been following a basic tutorial for droplet combustion: https://www.youtube.com/watch?v=sg3jcwZGXM4&t=310s
I think the only major difference is that I've specified .00096 kg/s injection flow rate of diesel fuel (.5 equivalence ratio) in the discrete phase tab. When I run my iterations, the mass flux reports double that: .00192 kg/s. Is this my error or can Fluent only work with stoichiometric ratios for droplet combustion? Also, I have trouble achieving continuity convergence - always more than 1e-2 and net mass flow continues to change. I'm using a coupled solver with Courant # = 4, .1 pressure and momentum UDFs, PRESTO! for pressure, and second order for all others. I imported cold flow interpolation that had good convergence. Any help with hot flow convergence is appreciated. |
combusting particle, convergence failure, diesel injection, dpm fluent, mass flux |
Discrete Phase Model, outlet mass flow rate does not fit | edu_aero | FLUENT | 29 | February 3, 2020 09:38 |
Specify mass flow rate for periodic boundary conditions in channel flow | lion1990 | OpenFOAM Running, Solving & CFD | 1 | July 9, 2018 18:46 |
Mass flow rate boundary condition with negative values | ashtonJ | CFX | 3 | November 26, 2014 06:21 |
Mass flow rate of phase in post | mat_cfd | CFX | 0 | September 3, 2013 08:55 |
Mass flow rate of the DPM mass sourse ?? | Rhinocao | FLUENT | 3 | January 21, 2011 13:10 |
