error in the beginning of parallel porocessing |
February 14, 2017, 09:36 |
arash
Rep Power: 17 |
when I run the Fluent I see this message:
Updating mesh at time level N... MPI Application rank 2 exited before MPI_Finalize() with status -1073741819 The fl process could not be started what is meaning of this message? |
February 15, 2017, 00:15 |
Lucky
Rep Power: 66 |
Looks like an MPI problem. Can you describe your setup a little more? Is this a new issue or never before seen? Basically, a Fluent process did not start on one of the parallel nodes as expected. Did your nodes even boot up properly before that?
Have you tried tinkering with your MPI? Is this on a compute cluster or a workstation/desktop? |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 05:18 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 12:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 17:49 |
Parallel Processing: from the beginning | Ness | FLUENT | 3 | June 27, 2007 16:49 |
