problem with creating artery thickness for FSI methode using fluent and mechanical
Old   February 12, 2017, 11:32
Default problem with creating artery thickness for FSI methode using fluent and mechanical
ramin
raminostadi is on a distinguished road
Hello experts.
I'm working on blood vessel with FSI methode. I have a stl file for artery(without
thickness) and convert it to IGS. and there is no problem in modelling it as a
fluid zone(no FSI) by fluent.now for FSI methode I need to create 0.7mm thickness for wall and when I Create 0.00001mm thickness there is no problem.
for that I create a surface body in design modeller and I put 0.7mm for thickness in ansys mechanical based on totorial.. but when I create thickness,there is a hole or empty space in artery.I use different methode for create thickness such as thin surface option in design modeller and fill methode after that but no result.
please help me. have ansys mechanical or design modeller a option for solving this problem?I'm very dissapointed.
please give me some advice.
raminostadi is offline   Reply With Quote
Old   June 6, 2020, 06:17
Farhan Muhib
farhan97 is on a distinguished road
Though it is too late, this problem will be solved if after loading the geometry, you open it using the design modeler and use the "Stitch" function in the "Repair" section.
Hope it helps.
farhan97 is offline   Reply With Quote
FSI problem with system coupling: Fail to couple FLUENT sophieUNSW FLUENT 16 October 1, 2020 06:20
Acoustic Analysis using Fluent and ANSYS mechanical ankit1512 ANSYS 0 November 10, 2013 19:46
Exporting fluent melting/solidification model results to ansys mechanical apdl omair11 ANSYS 3 August 28, 2013 07:22
