what should be the gauge pressure
Old   February 8, 2017, 10:29
Default what should be the gauge pressure
arch v is on a distinguished road
I am carrying on a project wherein it consists of a chamber in which i am sending LPG and AIR at a proper ratio so that it should mix up and it should be burnt completely.
I am having my velocities of the 2 inlets, the chamber is working at the room temperature.
What should be the initial gauge pressure at the 2 inlets. ie, inlet air and inlet fuel. Also what should be the pressure outlet.??
I am confused to give initial gauge pressure as 101325 pa or 0 pa??
arch v is offline   Reply With Quote
chamber, initial gauge pressure, pressure outlet, velocities
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 06:35
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 18:16
Discharge of Pressure Vessel into Pipe with Regulator gajowni2 System Analysis 0 October 31, 2015 19:57
Gauge Total Pressure and Gauge Pressure in Isentropic Flow Riena Shin Main CFD Forum 0 May 6, 2012 12:28
SUPERSONIC/INLET GAUGE PRESSURE Marco Giuliani FLUENT 1 December 19, 2005 02:24
