Total Surface Heat Flux in a Volume
Old   February 8, 2017, 04:56
Question Total Surface Heat Flux in a Volume
Mickael Perrin
Myki90 is on a distinguished road
Hello everyone,
I am a student and I actually work with ansys Fluent on an heat exchanger : Water Charge Air Cooler in cross flow. The fluids are water (52.5°C) and air (220°C). The goal is to transfer heat from air to the water so after simulation, I need to export the heat flux.
To avoid to research every contact surface, I use a volume integral to get the heat flux for every volume (air, water and aluminium) and then I multiply the heat flux (in W/m²) by the surface (m²) of each zone to get the real flux (W).
However when I proceeds, the energy balance isnt zero : the flux lost by air isnt the same gained by the water.
This is the geomtry i study :
To limit the number of cells, i do a planar symmetry according to the plan ZX in the middle of the air pass.
For exemple :
- thickness aluminium : 1 mm everywhere.
- lenght air : 30 mm
- height air : 6 mm
- width air : 2 mm
- lenght water = width air + 2*thickness alu = 4 mm
- height water = 1.6 mm
- width water = lenght air - 2*thickness alu = 28 mm
For this case, the air lose 0.87 W and the water get 0.86 W, (the aluminium at 0.0035 W is irrelevant acording to me) so there is a balance of 0.01W.
Can someone tell me where it come from ?
For this exemple the balance is about 0.01W but for some others, it can grow up to 0.3 W (the air lose 0.65 W but the water get 1,1W).
Thanks everyone for your help and your time
Cordially
Mickael
Myki90 is offline   Reply With Quote
heat exchanger, total surface heat flux, wcac
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Total Surface Heat Flux cfmyd FLUENT 0 June 27, 2014 17:00
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Total heat flux vs surface integral Al FLUENT 0 December 22, 2008 13:16
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
