Error while running a Fluent Simulation in Hpc cluster
Old   February 7, 2017, 06:10
Unhappy Error while running a Fluent Simulation in Hpc cluster
Amit Koikkarah Aji
averageindianjoe is on a distinguished road
Greetings Members,
I wrote an User Defined Function in C and that udf works perfectly on my local node but it begins to crash on my Linux HPC cluster whenever I input it.
For the cluster operations, the C file was kept along with the .cas file , journal file and shell file in the same folder. The thing is the cluster simulation works well only for constant velocity but it does not work for the udf file . However it works well on the user defined function.
I tried debugging it a lot but it was to no avail that I made any progress regarding it. I am thus attaching my journal file,New Text Document (4).txt
newjournal.txt
bernhard.c udf and the error file .
If its possible can someone could suggest where the error might have propagated from.
averageindianjoe is offline   Reply With Quote
Running Fluent by Hyper-threading Anna Tian FLUENT 13 January 13, 2021 16:01
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Having problems running transient fluent simulation in batch mode obylong FLUENT 1 August 15, 2014 00:58
Huge file sizes when Running VOF simulation aarratia FLUENT 0 May 8, 2014 13:27
Replacing mesh while running a simulation akultane CFX 1 November 15, 2009 14:46
