DPM-Number of streams in pressure swirl atomizer
Old   February 6, 2017, 06:34
Lightbulb DPM-Number of streams in pressure swirl atomizer
Zari Musavi
Zari is on a distinguished road
I want to model a single hole-solid cone injection of a liquid. The model is 2D-axisymmetric swirl. I have chosen pressure-swirl atomizer, since the cone models are only available in 3D, then I know that the model will consider hollow-cone (is this correct?).
the liquid flow rate is 1.4 g/s.
spray half angle: 30 deg.
upstream pressure: 4 atm.
Injector inner diameter: 0.2 mm
How should I decide about entry of 'number of streams'??
I looked at many forums and at the Fluent manual, seems that the number of streams will be used for calculation of mass of every particle.
Since we enter the total injection flow rate, pressure, and injector diameter, it is expected that the number of the streams could be calculated. I am confused about this entry.
Zari is offline   Reply With Quote
Old   February 7, 2017, 04:53
Question
Zari Musavi
How the 'number of streams' and mass flow rate of fuel are related to each other?
dpm, number of streams, pressure swirl atomizer
decomposePar no field transfert Jeanp OpenFOAM Pre-Processing 3 June 18, 2022 13:01
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 15:53
Pressure Swirl Atomizer Vijay FLUENT 0 August 8, 2011 12:12
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
