Saibal
Rep Power: 9 ![]() |
Hello friends,
I am doing a simulation on sub-sonic diffuser(Divergent nozzle) using ansys fluent, I am not able to get the exact result what it has to come actually. As it is known to all of us that during subsonic flow diverging cross-section will be acting as diffuser, where velocity will decrease at the outlet and simultaneously pressure will increase.But, in my case I am getting a reverse result. Pressure is decreasing and velocity is increasing. I am completely describing my problem details: For the case of diffuser: Inlet Diameter-55 mm. Outlet diameter-110 mm. Inlet pressure- 410043 Pascal Inlet temperature-483 K. Inlet gas-Air Inlet Density-2.9563 kg/m3 Inlet velocity- 397 m/s. As the temperature at the inlet is 483K, Mach number at the inlet is 0.9 as the velocity of sound at inlet is around 440 m/s. During problem solving through Fluent, I have used P inlet as the inlet boundary condition.Gauge total pressure is 693400Pascal as I found it from isentropic table corresponding to M=0.9. Initial gauge pressure is 410043Pascal and Inlet temperature is 483K. For the outlet case. I have used P outlet as the boundary condition and the gauge pressure at outlet is 101325 Pascal. When I did not get the result, I changed the P outlet gauge pressure value to a higher pressure value than the Pinlet, but at that time also I found errors like reverse flow condition and divergence of the solution etc. In the solution method I used Implicit+AUSM second order upwind scheme. After solving this problem, I found the solution as velocity is reaching to 550m/s and the pressure is decreasing simultaneously. Please suggest me where actually I am doing mistake, so the result is not coming properly. |
high velocity flow, pressure and velocity, subsonic diffuser |
restarting paused transient simulation using reactingFoam | JMDag2004 | OpenFOAM Running, Solving & CFD | 1 | August 10, 2015 10:15 |
Which turbulence model is applicable for Plain diffuser flow simulation in openFOAM? | mukut | OpenFOAM Running, Solving & CFD | 4 | January 30, 2015 08:06 |
Use homogeneous results as the initial guess for an inhomogeneous simulation | JuPa | CFX | 5 | December 26, 2014 13:44 |
Discrete event simulation vs. fixed time (discrete time simulation) | jenjon | FLUENT | 0 | March 10, 2013 06:58 |
Solver For low subsonic speed simulation | firda | FLUENT | 0 | January 28, 2011 07:45 |
