porous media in pebble bed
Old   February 1, 2017, 06:58
Default porous media in pebble bed
Darshan C
Darshan C is on a distinguished road
hello
As I am working on passing air as a working fluid inside a cylindrical chamber consisting of spherical pebbles(which have a porosity of 0.2) and the pebbles occupy 50% of the region in flow volume. What are the cell zone conditions needed to be given to the pebbles as well as the flow volume.
I have taken the pebbles as porous region.
Under steady state simulation I need to get a pressure drop of 5 Pa. But I am getting a drop of 0.2 Pa. (Note: It is a 2 dimensional model).
I have referred the model from (CFD Analysis for the Hydrodynamics and Heat
Transfer in Packed Pebble Bed)
by
N.S. Ghuge & D. Mandal
Darshan C is offline   Reply With Quote
Old   February 1, 2017, 08:05
Kushal Puri
Kushal Puri is on a distinguished road
Originally Posted by Darshan C View Post
hello
by
You can define that as a porous jump condition and define the appropriate value of face permeability, porous medium thickness and pressure jump coefficient
Kushal Puri is offline   Reply With Quote
Old   February 1, 2017, 10:04
Default porous pebbles
Darshan C
Thanks for the quick reply sir.
In my case the pebbles are the porous medium so what should be the value for porous medium thickness.
Old   February 1, 2017, 10:18
Kushal Puri
Can you show mesh image
Old   February 1, 2017, 11:32
Darshan C
The modelling and meshing was done using gambit
Old   February 1, 2017, 11:35
Darshan C
this is the full model meshing
Old   February 1, 2017, 11:36
Darshan C
this is the meshing between the pebbles and flow volume
Old   February 1, 2017, 11:58
Kushal Puri
Actually no need to capture the pebels, you just make that a make mesh without pebels and define the porous coefficient. This is what porous modeling is.
Old   February 1, 2017, 12:29
Darshan C
Sir in the simulation that i am doing the pebbles are actually treated as a porous medium (darcy's law) whereas the flow volume surrounding it isn't (Navier Stokes equation).When modelling I have subtracted the pebbles from the flow volume, hence making it two separate volumes.I have no problem while meshing but when running the simulation under steady state laminar condition at a flow rate of 0.0016125 kg/s I had to obtain a pressure drop of 5 Mpa but my pressure drop is very small about 0.2.I had given pebble only as a porous medium and not the other volumes and also given the respective boundary conditions as stated below in the diagram.
Sir please tell me if I have gone wrong anywhere while simulating it.
Old   February 1, 2017, 12:33
Darshan C
This is the plot against which i want to validate my results
Old   February 1, 2017, 12:52
Kushal Puri
Can you send the case
pebbles, porous
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
porous media model validation Tensian FLUENT 0 September 23, 2016 06:04
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 11:34
porous media in packed bed N. Dwivedi FLUENT 10 September 18, 2003 07:12
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 16:16
