Y plus Calculation
Old   January 31, 2017, 09:03
Exclamation Y plus Calculation
Alejo
Alejo7774 is on a distinguished road
Hello everyone,
I would like to know how Fluent calculates de Y+ parameter from the velocity field ? I know the definition of this parameter:
Y+ = U_tau * Y_node / Kinematic_Viscosity
With Y_node the distance from the center of the volumen to the wall; ans U_tau the friction velocity. This velocity is calculated as:
U_tau = (T_tau / Fluid density)^(1/2)
With T_Tau the wall shear stress. This value is deficed as:
T_Tau = Dynamic_Viscosity * (du/dy)_(y=0)
With (du/dy)_(y=0) the slope of the parallel velocity in the normal direction to the wall.
What I do not understand is how I could determine this derivate value at the wall if I only have the velocity field at the center of the control volume closet to the wall? Besides, when I am using a wall function I am far from the wall, so how can I obtain the value of the friction velocity?
Does Fluent use the log-velocity profile to define if the cell is in the sub-viscous layer or the turbulent layer ?
Best,
Alejandro
Alejo7774 is offline   Reply With Quote
friction velocity, log. velocity-profile, wall shear stress, yplus
Dynamic mesh adaption in parallel calculation xh110120 FLUENT 1 March 12, 2016 09:05
Determining the calculation sequence of the regions in multe regions calculation peterhess OpenFOAM Running, Solving & CFD 4 March 9, 2016 04:07
Quick Question on Calculation Time Davitt COMSOL 0 January 14, 2016 15:16
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 09:46
Warning 097- AB Siemens 6 November 15, 2004 05:41
