January 23, 2017, 16:21 |
Pico Hydro Turbine CFD Modelling
Nash
Hi everyone,
I am currently working on project to develop a CFD model of a pico hydro turbine using ANSYS Fluent. As seen in the images attached, I have decided to isolate my component as I only want to run the CFD analysis on the turbine propeller to improve its design efficiency. Currently I have managed to create the model geometry and do the meshing but I have certain issues with the setup. I have used this link https://www.youtube.com/watch?v=KFrZoDWUC5s as a reference as my turbine is also axial flow but uses water instead of air so I am not so sure with regards to the Boundary Conditions settings. I am also not sure if I am about the correct steps and would appreciate any inputs. Please advice if I am in the right direction. Problem : 1)How do I do my settings for my setup ? (Frame motion and etc ?) 2)And what are my boundary conditions to select ? Facts : 1. Low head turbine (using 1.5m head) 2. Water velocity = 3 m/s (average by calculation) 3. Water flow is based on gravity (no pumps or etc, can be seen from the image attached) 4. Power output from turbine 1 kW Thanks in advance for taking your time to help me. |
axial turbine, hydro turbine, pico hydro |
CFD in Naval Hydrodynamics, Off-Shore and Wave Modelling with OpenFOAM | hjasak | OpenFOAM Announcements from Other Sources | 2 | February 13, 2017 04:59 |
Opinion of this self built workstation for CFD modelling | Hajart | Hardware | 28 | December 14, 2016 17:18 |
CFD analysis on wind turbine rotor | Ken (Wind Turbine CFD Super Rookie) | Main CFD Forum | 45 | February 9, 2016 14:07 |
CFD beginner: Looking for vertical turbine simulations in OpenFOAM | Leeyan007 | OpenFOAM Running, Solving & CFD | 0 | October 23, 2015 11:14 |
Future CFD Research | Jas | Main CFD Forum | 10 | March 30, 2013 12:26 |
