"The FLUENT application failed to validate the connection." problem |
January 23, 2017, 11:36 |
Rafau
Rep Power: 13 |
Hey,
I went through geometry design, mesh and then i want to start up with fluent, but it does not work. The solver stops just at the beginning and after few minutes the error appears. "The FLUENT application failed to validate the connection." I have an Ansys 17. any suggestions? Regards |
January 24, 2017, 04:44 |
Rafau
Rep Power: 13 |
February 25, 2017, 22:24 |
I'm running into the same problem. Did you figure out how to resolve it?
April 5, 2017, 22:57 |
Sakeen
Rep Power: 9 |
Same problem here!
April 20, 2017, 01:54 |
Update internet explorer to IE11
Chaitanya
Rep Power: 13 |
You need to update the Internet Explorer to 11 or latest
License information for the License manager is sent through IE. |
validate.application |
Problem in compiling fluent UDF lunched from MATLAB | cfdman10 | Fluent UDF and Scheme Programming | 16 | December 5, 2019 06:32 |
Ansys Licence Serve on Ubuntu 16.04 LTS | david.pasquale | ANSYS | 2 | January 20, 2017 12:52 |
Fluent Parallelization Problem After AC Power Dropped | pawl | Hardware | 5 | November 13, 2016 07:08 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 11:54 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 03:00 |
