Creating & Meshing 2D Planar Surface (for simulating 2D Centrifugal Fan)
Old   January 21, 2017, 13:02
Default Creating & Meshing 2D Planar Surface (for simulating 2D Centrifugal Fan)
Arrows is on a distinguished road
Hi everyone,
I'm relatively new to Ansys Fluent, so apologies if this turns out to be a dumb question...
My aim is to setup a 2D flow simulation of a forward-curved centrifugal fan. However, I have been struggling on the creation of the geometry.
I have previously not experienced any problems importing 3D Solidworks geometry into DesignModeler. For 2D geometries, am I right that it would only work if it involves planar surfaces created from closed-loop sketches (eg: complete circle, rectangle etc.) ?
My original plan was to first create a 2D circular disk of zero thickness, then drawing and circular patterning the outline of the centrifugal fan blades, then making zero thickness planar surfaces out of the blades as well, but I was stuck on the problems illustrated from the two attached images.
So somehow, whenever I tried to mesh the imported 2D geometry, even if its just a plain zero thickness circular disk without the blade outlines drawn on it, it would somehow extrude itself into a 3D column. Just wondering if anyone could point out what I had done incorrectly ?
__________________________________________________ __________________________________________________ __________________________________________________ ________
This problem did not occur if I tried drawing the geometry just from DesignModeler, but for drawing complex geometries like the blades, does DesignModeler have the features from other CAD programs like Solidworks (eg: centreline, circular pattern, equation-driven curves etc.) such that I can define the 2D blades (eg: inlet angle, outlet angle etc.) ?
Arrows is offline   Reply With Quote
2 dimensional, centrifugal fan, designmodeler, mesh 2d, solidworks
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
How to model flow of centrifugal fan? Peter Main CFD Forum 0 April 2, 2008 07:07
meshing a fan using gambit tony FLUENT 1 February 15, 2008 01:28
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
