steady analysis
Old   January 18, 2017, 23:15
Default steady analysis
manar
manar is on a distinguished road
Hello Guys
I have a question regarding the steady analysis :
*How to justify the fluid velocity if it is a steady state problem , I know if the fluid is moving that mean it does not come to steady-state completely n is there any criteria for that ?
*about convergence : are the default residuals minimum ? what if I got 2.5e-2 for continuity residual for example ?????/?
manar is offline   Reply With Quote
Old   January 19, 2017, 03:29
Antanas is on a distinguished road
You're wrong. Based on conditions flow can come to steady-state regime which means that its parameters don't change with time in every spatial point of flow region, that is flow pattern is steady (frozen) in time.
Antanas is offline   Reply With Quote
Old   January 19, 2017, 05:53
manar
thanks Antanas
sorry I am not familiar with Fluent that much , what I got from you is that Fluent consider steady state when the fluid parameters come into zero in the edges , ie:Outlets and walls , Is that correct ?
Old   January 19, 2017, 11:45
Lucky
It might be clearer if you call it steady-flow. The rate of flow attains a steady value (velocity is time-independent).
Velocity going to zero at walls is a boundary condition.
Velocity =0 at an outlet is paradoxical, either there is no flow or it is not an outlet.
Old   January 19, 2017, 12:52
thanks Antanas
Not at all. It's not about Fluent, it's about physics. Steady flow regime means that in the process of fluid flow its parameters (velocity, pressure, density etc.) at every point in the flow don't change with time. Understand? In steady flow parameters may vary only spatially.
Old   January 21, 2017, 21:19
manar
very clear Antanas and Lucky Tran
cfd, fluent
Eigenfrequencies static and modal analysis Laura_mecheng ANSYS 1 May 15, 2012 04:40
3D analysis of Ahmed body Irshad22 FLUENT 0 December 17, 2009 05:33
pls help.How to do thisblade passage analysis ??? kaen FLUENT 0 January 19, 2006 09:54
how to do blade passage analysis of turbine? kaen FLUENT 0 January 17, 2006 23:49
Using turbulence model for steady state analysis Terry FLUENT 7 February 28, 2001 08:03
