January 12, 2017, 10:20 |
Dynamic mesh mesh deterioration
Rep Power: 10 |
I am using Fluent's dynamic meshing around a deforming airfoil , however the Minimum Orthogonal Quality goes way under 0.01 when it is deformed. I checked the cell where this low quality is but it looks ok. I am using spring based smoothing and remeshing with a quadrilateral mesh. Does the re-meshing handle quadrilaterals? Will this low quality affects the flow and is there any method to improve the mesh? Thanks |
dynamic mesh, orthogonal quality, quality check |
Dynamic Mesh on Pintle type injector. | herntan | FLUENT | 16 | September 4, 2020 08:27 |
pls help. mesh collapsed with dynamic mesh. | wlt_1985 | FLUENT | 2 | May 7, 2020 10:42 |
[ICEM] Dynamic mesh setup with ICEM | David121284 | ANSYS Meshing & Geometry | 0 | April 11, 2014 04:19 |
Dynamic Mesh "Shadow Wall" | thezack | FLUENT | 0 | June 4, 2013 22:09 |
dynamic mesh for drop interface | IndrajitW | FLUENT | 0 | March 30, 2013 08:03 |
