Rep Power: 9 ![]() |
Hi guys
I am trying to simulate a particle tracking project in a 90 bend with DPM model in fluent 14. the viscous model is RSM-EWT. In DMP model i set the " Max number of steps" to 5000 and " step length factor" to 5. there is no interaction between particle-particle and particle-continuous phase. I have used Rungt-kutta method for "tracking scheme". I also created an injection with this following option: injection type: surface-inlet particle type: inert inject using face normal direction: d=4.7e-06 m v=18 m/s flow rate=1.2e-09 kg/s this is equal to 25000 particle. in every run that i have performed just 336 particle were tracked. I have changed the flow rate,velocity,diameter,number of steps but in all cases results were same. Can any one help me to solve this problem? |
#2 | |
engeagle
Rep Power: 10 ![]() |
I dont think so because the number of particles that traped in the geometry was different in each result. But thanks anyway
dom model |
DPM Erosion Model Question | CFDD | FLUENT | 0 | August 21, 2013 19:06 |
DPM model | doskivish | Main CFD Forum | 0 | July 3, 2013 05:35 |
How to put melting Point data of inert particle in DPM model | subhankar_bhandari | Main CFD Forum | 0 | July 26, 2010 07:28 |
DPM model in FLUENT | Jürgen Schmidt | FLUENT | 0 | October 27, 2005 14:39 |
DPM vs Species transport model | osh | FLUENT | 0 | August 19, 2005 22:15 |
