Question about Wall-functions and initialization.
Old   January 11, 2017, 14:50
Default Question about Wall-functions and initialization.
Boris
Hawxliquid is on a distinguished road
Hello !
I have two, probably basics, questions.
My first one is about wall functions. I am wondering if wall functions models all the sublayers of a boundary layer, or only a sublayer? (Viscous,Buffer and log law).
My second one is a bit more specific, it probably applies to all CFD programs, but I am used to Fluent.
It concerns initialization. It seems that hybrid initialization solves Laplace's equations for p and V, but how does a so called 'standard' initialization works ? Constant values ? Static case ?
Thank you !
Hawxliquid is offline   Reply With Quote
Old   January 11, 2017, 20:38
Jingchang.Shi
aerosjc is on a distinguished road
1. I guess you are asking about wall function in Fluent. It models viscous sublayer and log-law region. See [Fluent Theory Guide](http://www.afs.enea.it/project/neptu.../th/node99.htm).
2. Standard initialization just use what you specify in the panel to initialize the flow field. Const value.
aerosjc is offline   Reply With Quote
Old   January 12, 2017, 05:23
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Well, it actually depends on the specific wall function model.
Fluent has all kinds of models ranging from "only log" to "log + viscous" to "log + viscous + buffer".
As another example, check this:
https://www.cfd-online.com/Forums/bl...on-part-1.html
and the following parts (2-3).
sbaffini is offline   Reply With Quote
Old   January 12, 2017, 11:42
Boris
Thanks to you two !
Retaining UDM on Initialization; Switching Between Series and Parallel Setup hebush Fluent UDF and Scheme Programming 3 July 6, 2016 11:09
Pointer Initialization SprayStef OpenFOAM Programming & Development 0 December 17, 2014 14:58
