How to calculate moment of inertia for the falling box?
Old   January 11, 2017, 12:03
Default Why the falling box does not work properly after scaling down?
Hossein1 is on a distinguished road
While falling box works well with the actual dimensions, it does not give a reasonable result when you scale-down the box dimensions.
Hossein1 is offline   Reply With Quote
Old   January 14, 2017, 21:04
I tried changing UDF as well as applying some other adjustments. However, I finally found out the reason is that when solving a 2D problem, Fluent considers a depth of 1m for those objects, and that's what we need to consider in calculating the mass of the scaled object (for instance, a box of 2mm * 2mm * 1000mm)
6dof, falling box, moment of inertia
[ANSYS Meshing] How to generate the falling box mesh DESOUZADACOSTA ANSYS Meshing & Geometry 1 March 19, 2018 10:25
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
Tutorial 2D Box Falling into Water pedrin84 FLUENT 2 June 19, 2014 14:23
falling box 2d- Help me! az123 FLUENT 0 June 12, 2012 06:03
Immersol Simulation of a Heated Box Dong Phoenics 0 March 2, 2006 22:20
