January 11, 2017, 08:09 |
Plasma Actuator udf error
mohamed hares
Rep Power: 10 |
Hello!
Now I just follow A.Bouchmal's MS thesis "Modeling of Dielectric-Barrier Discharge Actuator". http://www.lr.tudelft.nl/fileadmin/F...l_Bouchmal.pdf However, the code which he atteched doesn't works. I compiled the code and input conditions but when I start calculate, the error "FLUENT recieved fatal signal [segmentation fault] occurs. after alloct all memory and user define scalar and hooking it it works well but at hooking the adjust function the error occurs Please help me to solve the problem. |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
