Phase Change Problem-how to get Temperature vs time graph/data
Old   January 6, 2017, 00:37
Thumbs up Phase Change Problem-how to get Temperature vs time graph/data
Engr.GRH is on a distinguished road
Hey! Respected Members,
I am trying to analyze heat transfer in a phase change material (PCM). My material is solid at room temperature and it melts down at 60-62 ℃. I fill PCM in an Aluminum tank with an open top and it would be heated from the bottom side. I have to carry out the analysis in TRANSIENT mode. I use the models with ENERGY EQUATION and SOLIDIFICATION/MELTING ON. My final goal is to get temperature vs time graph. I simply know that there is a serious need to specify the locations/points by going into section of SURFACE > ZONES for getting temperature data; however I am unable to do it exactly. I would appreciate if someone can show me how to draw temperature vs time graphs as shown in the attached figure? Besides, I am not sure whether I should turn MULTIPHASE model ON or OFF during simulation, since my material also undergoes phase change at 60 ℃? I request you to kindly resolve my query.
Thanks a lot!
Engr.GRH
Engr.GRH is offline   Reply With Quote
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 04:41
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
Temperature time table problem ewentry STAR-CCM+ 1 August 29, 2012 17:03
