LES Open bounded jet - Smagorinsky or one equation KE?
Old   December 28, 2016, 12:47
Default LES Open bounded jet - Smagorinsky or one equation KE?
diogof is on a distinguished road
Hey everyone,
I'm currently working on a FLUENT assignment which involves the use of LES in order to simulate a turbulent pulsating jet. The physical problem consists of a jet with a rectangular base 0.1x0.02m, at the base of a 2x4x0.02m domain, where each of the 0.02m sides is meant to be modelled as a symmetry boundary, with two grid points along the 0.02m side. The pulse is sine wave which is defined as a function of time in an UDF. The side walls and top wall are open, whereas the rest of the bottom base is a wall.
I am currently having some difficulty trying to choose which subgrid-scale model to use.
I think I understand that the default WALE model, as well as the WMLES models are probably not the best models to use in this case because they are tuned for wall-bounded flows. I think the best two options are either the dynamic Smagorinsky-Lilly (eddy viscosity) model or the Kinetic Energy Transport model.
When looking at papers online however, I can't find any reasons to choose one model over the other, and so I am stumped when trying to justify which model I have used and why. Do you have any recommendations?
Thank you in advance!
diogof is offline   Reply With Quote
Old   January 3, 2017, 19:11
Lucky
I agree, ignore the WALE and WMLES stuff since they are not appropriate.
The original Smagorinsky-Lily and dynamic Smagorinsky SGS models are algebraic. The kinetic energy transport solves a transport equation for the subgrid scale kinetic energy. In this regard, I think the kinetic energy transport model is vastly superior (in theory). It's similar to using Prandtl's mixing length as a turbulence model versus the one-equation Spalart-Allmaras model. How well this theory is implemented and how accurately the numerical results compare with real world is another story.
Furthermore, I wouldn't expect much difference between original Smagorinsky versus Dynamic Smagorinsky. They should be similar.
Old   January 13, 2017, 15:36
Thanks for your advice! For most of the results I've seen on papers, when comparing Smagorinsky and kinetic energy transport model to real-world data they both seem to be pretty close. I think I can justify using either one.
jet flow, kinetic energy, les, model, smagorinsky
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 15:30
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 03:36
