December 21, 2016, 14:55 |
Convergence issue!
SinaJ
Rep Power: 16 |
Hi
I'm having a convergence problem for Steady state (SS) solution in a huge water tank flow simulation. I'm doing realizable k-epsilon (y+ ~50) there is a good residual convergence (like 1e-5 and -6) for all variables. but when I monitor some random points in the flow, I get very fluctuating velocity magnitudes in those points. Do you have any comment on why this happens and how I can fix this? (I guess the reason is the fact that there is no solution with local convergence for a high turbulence flow!) |
Convergence issue with continuity equation | Jake | FLUENT | 8 | June 6, 2018 03:41 |
convergence issue for transonic turbulent case | aeroiitkgp | SU2 | 5 | May 12, 2015 16:44 |
convergence issue with turbulence | mar | Siemens | 5 | February 2, 2015 02:42 |
Convergence issue | dhaya400 | FLUENT | 1 | December 5, 2014 09:58 |
Convergence issue | Jake | FLUENT | 3 | June 30, 2005 04:12 |
