Calculating total heat transfer
Old   December 16, 2016, 08:01
Default Calculating total heat transfer
da
arash509 is on a distinguished road
Hi
I designed a 2D canal with constant temperature walls. The fluid is Air and the inlet temperature is 300K. I want to calculate heat transfer rate. I use (Flux report>Total heat transfer rate). I have two questions:
1- when I change reference Depth in (Reference values>Depth) the Total heat transfer rate change. Why heat transfer rate depends on this reference value?
2- I don't know why that results is wrong because I choose (inlet) and calculate the Total heat transfer rate on inlet domain, But it is different with the Q=mh=mCpT (For ideal gas)
arash509 is offline   Reply With Quote
Old   December 16, 2016, 10:08
Kevin
KevinZ09 is on a distinguished road
Hi Aran,
Some, hopefully useful, quick answers:
1: The total heat transfer rate for conduction depends on the temperature gradient, which depends on the depth of the wall.
2: Enthalpies are always relative values; relative to a certain temperature. Fluent uses 25C (298.15K) I believe, but you may want to check that.
KevinZ09 is offline   Reply With Quote
Problem with total heat transfer rate aswathy_raghu FLUENT 9 April 21, 2022 11:36
Multiphase heat transfer pkladisios CFX 8 June 7, 2016 02:41
Heat transfer from a heated plate using fins pathakamit FLUENT 1 April 30, 2013 05:07
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Error in run Batch file saba1366 CFX 4 February 10, 2013 02:15
