benancio
Rep Power: 11 ![]() |
Hi all,
can someone please let me know how to create iso-clips using TUI cammand or by a journal file. I know that I should use surface/iso-clips, however I don't know the order for the rest of the parameters such as radial coordinate and max, min value and so on. Thanks |
Rep Power: 6 ![]() |
Example is the following:
/surface/iso-clip mixture x-coordinate clip-x-coordinate-1 clip-volume-fraction-1 0 0.0254 This from a multiphase model (VOF). "of domain" : mixture "iso-clip of" (clip to values of) : x-coordinate "new Surface id/name" : clip-x-coordinate-1 "from surface" (clip surface) : clip-volume-fraction-1 "lower threshold" (Min) : 0 "upper threshold" (Max) : 0.254 |
iso-clip, journal files, surfaces, tui command |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
