December 13, 2016, 01:11 |
UDF variable definitions
Rep Power: 13 |
Hi all,
I want to create a udf to write some variables to a data-file (text based to be plotted / analysed outside of fluent). I have some experience with udf's etc but now I wanted to know if there is a full list of variables available in fluent and the arguments needed to call for them. So looking for a list of variables / arguments ... This could be really trivial but I dont seem to find it anywhere. For example found this,but my question is thus how do you know that N3V_VS is an existing argument for the force you are looking for .. N3V_VS(Force_viscous,=,F_STORAGE_R_N3V(f,thread,SV _WALL_SHEAR),*,-1.0); Thanks in advance for the help! |
December 13, 2016, 11:50 |
Rep Power: 11 |
you can look in the storage.h file located in your installation folder to see all the variables availables. It might help you. Fanch |
December 14, 2016, 21:49 |
Thanks
Rep Power: 13 |
Figured it out now, thank you for the help!
Setting cell variable values in a fluid zone using UDF | eromon84 | Fluent UDF and Scheme Programming | 6 | March 28, 2021 11:59 |
udf for variable cp | B.Hamada | Fluent UDF and Scheme Programming | 2 | April 22, 2015 14:20 |
UDF extern variable - mean time moment coefficient | enry | Fluent UDF and Scheme Programming | 0 | November 14, 2009 06:51 |
name variable in UDF using Thread : syntax error before numeric constant | Laurence Wallian | FLUENT | 0 | October 8, 2009 09:18 |
UDF: exporting a variable between two DEFINE function | Carlo | FLUENT | 3 | August 19, 2009 12:21 |
