Setting the mass flow through a valve by moving the gate opening |
December 11, 2016, 18:06 |
Rep Power: 10 |
I apologize if I'm reopening an old thread but I can't find the answers I need. I'm kinda new in the CFD world and right now I'm practicing the Parametric Analysis, I need to fix the mass flow through a valve, the flow is compressible and the fluid is air. For this I only have to move the geometry, the gate oppening. I want to ask you about the general steps I need to follow. And if it will be possible some example, because of the compressible flow it is hard to me for knowing the actual result. Thanks you. |
analysis, mass flow, parametric, valve |
Target Mass Flow Rate | Nitin | FLUENT | 9 | June 17, 2017 10:30 |
Exit Corrected Mass Flow Rate Mesh Sensitivity Study | s__s__s | CFX | 4 | July 20, 2016 11:46 |
Mass flow discrepancy | BenMUC | CFX | 3 | May 2, 2014 03:29 |
Mass flow rate prediction of Purge control valve using set pressure drop | enr_venkat | CFX | 11 | February 27, 2014 11:30 |
total mass loss/gain--simulating taylor couette flow | nwpukaka | OpenFOAM Programming & Development | 0 | February 12, 2014 18:57 |
