Fluid Flow Around NACA2412 Airfoil
Old   December 9, 2016, 18:25
Arrow Fluid Flow Around NACA2412 Airfoil
MURAT GÜNEŞ
muratgunes is on a distinguished road
Hi everyone,
I have a GRADUATION THESIS that is Fluid Flow Around NACA2412 Airfoil. I'll discuss Cl and Cd at different attack angle.However, I have a problem after zero attack angle in fluent. For example, at the 5 attack angle Cl and Cd values don't match with the experimental values, so I can't have costant value for Cl/Cd. What is the problem? mesh or boundary conditions or y+ value? I need help immediately.
Best Regards,
Murat Gunes
muratgunes is offline   Reply With Quote
Old   December 13, 2016, 12:52
fanch33 is on a distinguished road
the y+ value depends on the turbulence model (SA, k-e, SST etc.) you are using and if you use or not wall functions. Describe your case.
Fanch
fanch33 is offline   Reply With Quote
Old   December 13, 2016, 15:40
MURAT GÜNEŞ
I'm using the sst turbulent model.
Old   December 16, 2016, 19:16
So you need y+<1
Sent from my iPhone using CFD Online Forum mobile app
Old   December 17, 2016, 04:09
Antanas is on a distinguished road
Originally Posted by fanch33 View Post
Fanch
This is misleading statement.
So you need y+<1
Really? Why?
Antanas is offline   Reply With Quote
Old   December 17, 2016, 07:26
The SST allows the resolution of the boundary layer all the way down to the wall and work as a low Reynolds number, so you need to ensure that y+<1
Old   December 17, 2016, 08:45
Yes it allows it, but it doesn't mean that one needs it and that y+ needs to be < 1 for this.
Old   December 17, 2016, 08:52
It means that the sub viscous layer must be resolved so y+<5 ...
But y+<1 is better ...
Do as you want
Old   December 17, 2016, 09:09
Do as you want
y+ = 1 is the lowest limit.
Old   December 19, 2016, 17:03
Cool
mali28 is on a distinguished road
The performance of a wing has a critical influence on the overall performance of the airplane impacting the range, speed, climb rate, payload, maneuverability, runway length, etc. Performance degradation is often the result of flow separation over the wing. Adverse pressure gradient with low flow velocities in the boundary layer causes flow separation on the wing leading to significant reduction in lift. The prediction of flow behavior over the range of operating conditions in a flight is thus very crucial for optimal design and safety consideration.
mali28 is offline   Reply With Quote
naca2412, yplus
Problem with airfoil shape optimization robyTKD SU2 Shape Design 7 March 7, 2022 17:18
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 17:17
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
2D FFD Optimization RLangtry SU2 2 August 5, 2014 10:48
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
