December 6, 2016, 03:00 |
Define Source UDF Problem
codenamenone
Rep Power: 11 |
I am developing a compressibility correction for one of the newly developed turbulence models. Right now I am trying to verify if my definition of turbulent Mach number is correct. With details aside, I am basically running a define source term with return value of 0 with bunch of UDMIs define under the define source function. My prediction was that I would be able to get the UDMI values without the correction applied( since I am adding nothing to the transport eqs, I should obtain the same results). But it just diverges after idk many iterations. I have not added anything to the original transport equation. I just defined another source term with return value of 0. So I am just lost why solution is diverging. Does anyone know any information about this? Thank alot Han |
coding, fluent, source, udf |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 10:07 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 18:18 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 07:42 |
I have problem of UDF with turbulent premx source. | Z | FLUENT | 0 | February 16, 2005 04:34 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 04:43 |
