December 4, 2016, 19:30 |
Adding points to read results
Mateusz
Hi!
I want receive velocitygraphs in some points. I have 26 simulations and I have to read parameters in 80 points. How I can write coordinates of these points in Ansys Fluent using console? I was looking for in Help, but I haven't received the answer. Please, this is very important for my University. Thanks in advance! Greetings, Mat |
December 5, 2016, 08:05 |
KirMaks
Rep Power: 10 |
Hallo,
You can try to make it in CFD-Post, You can create a post-processing template there and read every file separately or You can use it in a batch mode with a script. Best regards, Maks |
December 5, 2016, 09:01 |
Mateusz
I need ASCII, Location: Cell Center and Delimiter: Space, and:
-Velocity Magnitiude, Velocity: X, Y, Z -all pressures (Static, Dynamic etc) -all subxxx options -Q crit and normalized -Wall Yplus -all of options with kinetic energy if is it available Everyting in every of my 75 points. Probably I can't receive these results in CFD Post. Could You tell me how I can write this script? Is it hard? Big thanks for Your answer! |
add, coordinates, fluent, point |
How I can introduce my power heat (W) in chtMultiRegionFoam? | aminem | OpenFOAM Pre-Processing | 32 | August 29, 2019 03:23 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 11:52 |
[OpenFOAM] How to compress results files so that paraview can still read them | mirko | ParaView | 2 | January 20, 2011 12:07 |
adding a shell for sensor points | Kian | Siemens | 3 | August 22, 2007 12:06 |
Code to read in results on a BlockMeshcreated mesh as structured arrays | brooksmoses | OpenFOAM Post-Processing | 0 | December 5, 2005 20:57 |
