what does oscialliation (or fluctuation) mean in residuals |
December 2, 2016, 06:23 |
Onur Özcan
Rep Power: 12 |
Hi all,
Is there any knowledge or experience you have ? Is it possible to affect results? Does URF decrease solution? Kind Regards, |
December 2, 2016, 10:26 |
Kushal Puri
Rep Power: 13 |
Decreasing URF so much is not a good solution for damping the fluctuation. You can reduce URF, but not so much because as you reduce the URF much your residual will automatically start decreasing, this is what URF for, but then it will not tell you the exact convergence.
December 2, 2016, 12:16 |
Onur Özcan
Rep Power: 12 |
So, what is the reason of residual oscillations in steady-state ?
December 2, 2016, 13:16 |
Kushal Puri
Rep Power: 13 |
It depend on the physics of the flow, swirl in the flow, reverse flow or some highly skewed cells may be the reason. Its not always that your residual has to be go down if you are getting periodicity in the fluctuations at some e-03 then you can make a judgement of the convergence from the other parameters, like mass imbalance, heat imbalance etc.
December 2, 2016, 15:56 |
Rep Power: 18 |
December 2, 2016, 16:12 |
Onur Özcan
Rep Power: 12 |
I was solving model in steady-state
December 3, 2016, 04:11 |
Rep Power: 18 |
That doesn't mean that you flow is absolutely steady (if at all). Still there may be transients which you resolve. So when you solving it in steady-state, residuals may stuck in regular oscillations. Therefore you should also monitor parameters of interest and if they become steady, then it's your solution. Or switch to transient solver.
3D velocity fluctuation profiles from a file in initialization section using LES. | Aramisss | CFX | 0 | July 8, 2015 17:24 |
motorBike Residuals for SST k-omega... and mine | JR22 | OpenFOAM Running, Solving & CFD | 6 | August 1, 2013 10:08 |
judging convergence through residuals | MachZero | Main CFD Forum | 7 | December 25, 2012 13:18 |
large fluctuation in residuals | ghost | FLUENT | 0 | January 4, 2010 22:09 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 06:45 |
