December 1, 2016, 08:39 |
#21 |
Onur Özcan
Rep Power: 12 |
you can find polynomial equations that is valid for steel.(its thermal expansion coefficient is high, its physical properties change with temperature )
as for water, pressure_inlet is tha you have defined as boundary condition ? compare results with something that attained by experimental or etc. |
December 1, 2016, 08:43 |
#22 | |
Vaclav Piskacek
Rep Power: 10 |
I have velocity inlet, because velocity changes in time, but pressure stays the same. |
December 1, 2016, 08:52 |
#23 |
Onur Özcan
Rep Power: 12 |
but pressure stays the same.[/QUOTE]
the reason why I wrote as pressure inlet was you , because you wrote it and defined its 24.5MPa. I am trying to solve your problem. I just think that the problem is relevant to precision. That's why it is better to write ''polynomial or polynomial piecewise equation in FLUENT. Moreover, if your geometry has different cross sections, pressure always changes , I could not know what it is your geometry visually. |
December 1, 2016, 08:57 |
#24 |
Vaclav Piskacek
Rep Power: 10 |
I just think that the problem is relevant to precision. That's why it is better to write ''polynomial or polynomial piecewise equation in FLUENT. Moreover, if your geometry has different cross sections, pressure always changes , I could not know what it is your geometry visually.[/QUOTE] http://imgur.com/a/grsRk I have inlets set like this... Constant pressure and profile of velocity. |
December 1, 2016, 09:05 |
#25 | |
Onur Özcan
Rep Power: 12 |
that's pretty good!, it must be something else the reason for mass imbalance. |
How to find cells whose skewness exceed 0.98 in Fluent? | swtbkim | FLUENT | 12 | March 5, 2017 10:31 |
[ANSYS Meshing] Problem with High Skewness Mesh | CFD2016 | ANSYS Meshing & Geometry | 12 | June 8, 2016 02:28 |
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting | arunraj | FLUENT | 0 | June 2, 2016 23:58 |
[GAMBIT] Problem with boundary layer - high skewness | Muffins | ANSYS Meshing & Geometry | 4 | February 28, 2014 08:34 |
[GAMBIT] tangent edges and high skewness | CaroVandame | ANSYS Meshing & Geometry | 8 | May 7, 2012 10:39 |
