Heat Transfer Coefficient not changing with fluid temperature/ Wall temperature
Old   November 30, 2016, 00:24
Default Heat Transfer Coefficient not changing with fluid temperature/ Wall temperature
cfd_msc
seshu1353 is on a distinguished road
Hello All,
I was trying to change fluid temperature and wall temperature and find out Heat transfer coefficient. But I'm getting a constant HTC.
note : Im using nanofluid properties
seshu1353 is offline   Reply With Quote
Old   November 30, 2016, 09:45
Lucky
Sounds correct! Heat transfer coefficient is a property of the flow and it shouldn't change with temperature, except in reality there are non-linearities.
Old   November 30, 2016, 13:08
Onur Özcan
oozcan is on a distinguished road
Originally Posted by seshu1353 View Post
Hello All,
heat transfer coefficient is actually convective heat transfer coefficient (w/m2K) and it is not flluid property. As Lucky train said, it only changes with flow model you have specifed
oozcan is offline   Reply With Quote
Old   December 1, 2016, 06:02
Kushal Puri
Kushal Puri is on a distinguished road
Hello All,
Can you explain the complete model. how you are modelling.
If the fluid flow rate is same and temperature is increasing or decreasing then htc has to be change. As there will be change in temperature difference.
Kushal Puri is offline   Reply With Quote
Old   December 1, 2016, 10:02
Lucky
The Nusselt number is a similarity variable and depends only on Reynolds number and Prandtl number.
Nu = fn(Re,Pr)
From
Nu=h*L_ref/k_ref
Heat transfer coefficient is thereby
h = Nu*k/L
There's no temperature!
Newton's law of cooling defines heat transfer coefficient as:
q" = h*(T-Tref)
Which means that if the temperature changes, the q" changes but not the heat transfer coefficient
The only reason heat transfer coefficient should change, is due to non-linearities. i.e. Reynolds number, Prandtl number, k_ref, L_ref are temperature dependent quantities. If the heat transfer coefficient did change, it would have to be for one of those reasons. However, if you tell me that you changed the wall temperature and heat transfer coefficient did not change, then I will automatically respond with it's not supposed to.
fluid temperature, heat tranfer coefficient, htc, wall temperature
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 14:32
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
