Minimum Size Constraints on Simulations Query
Old   November 28, 2016, 14:29
Question Minimum Size Constraints on Simulations Query
Craig Leddicoat
Leddsworth is on a distinguished road
Ahoy hoy,
Been running into bother meshing and running Fluent simulations involving exceptionally small geometry dimensions, around 1mm to 5mm wide fluid passages, and was wondering if there is some lower limit on the size Ansys can reasonably simulate?
From my analysis of the problem messages after trying a wealth of meshing methods, the automation seems to struggle with surfaces of the pipe walls and fluid boundaries and is creating interfacing at these dimensions that shouldn't be there. I have tried a few work around's already, including manually setting all the contact regions but I am still plagued by failing meshes, conflicting zone names and unresolvable contact regions.
https://i.imgsafe.org/c7512309b4.png
The image shows a sample of the heat exchanger concept, outer Fluid region, Central Pipe Wall Region and Inner Fluid Region.
Can anyone please advise a method to successfully mesh and discretize this model?
Leddsworth is offline   Reply With Quote
Old   November 28, 2016, 16:08
Lucky
There is a lower limit because Fluent works natively in meters, but it's around 1e-06 m. Fluent shouldn't have issues with mm scale features.
Old   December 1, 2016, 06:02
Craig Leddicoat
You are correct, Ansys is capable of computing simulations at dimensions this small.
The errors seemed to stem from automated face pairing for connections on a series of layer 3D curved faces. I managed to resolve the conflict by better defining the contacting parts by grouping parts together in the Geometry editor to minimise the number of contact regions in the Mesh editor.
Old   September 20, 2021, 05:06
Vincent
VincentVega is on a distinguished road
I'm sorry for reviving an old thread, but what exactly is the lower limit, and where can I find more about it? Couldn't find anything via Google and the manual.
I'm asking because it try to simulate a microjet (diameter of 1,3e-6m), and the 2D one turned out good. Now I wanted to draw a mesh for a 3D validation but ANSYS DesignModeler and Spaceclaim both don't let me draw simple circles smaller than 1e-5m in diameter - which let me in turn doubt my 2D solutions because there must be some reason for a restriction like that. My minimum volume (in 2D) is ca. 3e-24m^2.
Somebody in another thread mentioned round-off errors in small size domains and I guess this is connected. Is there anywhere where I can read up on that to make sure I'm not calculating nonesense?
VincentVega is offline   Reply With Quote
Old   September 20, 2021, 10:02
Lucky
Well, it gets a little more complicated when other software are involved but basically...
Eventually your stuff gets saved into a .cas file which can be binary but is usually an ascii text file with limited precision. The fastest way to appreciate this is to open your .cas file with a text editor, scroll all the way down so you can all the coordinates of the mesh points. Last time I checked it was around 6 digits.
fluent, heat and mass transfer, heat exchanger two fluids
courant number in vof reza_gharib1369 FLUENT 49 February 26, 2020 17:55
Reduce size of Ansys.rst file in FSI simulations? Jorn CFX 6 September 21, 2017 04:00
Minimum possible element size Tscar Main CFD Forum 3 February 12, 2016 14:50
Minimum mesh size for Advection-Diffusion Problem Murf CFX 4 March 5, 2015 15:15
minimum mesh size for CFX julien CFX 1 January 12, 2006 07:37
